跳转到主内容
Olympus 850SW Battery Replacement
你所需要的
  1. Olympus 850SW Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery compartment on the bottom panel of the camera.
  2. Olympus 850SW Battery Replacement: 步骤 2 中的图像 1,2 Olympus 850SW Battery Replacement: 步骤 2 中的图像 2,2
    • Using a PH00 Phillips Screwdriver, unscrew the one screw located on the latch.
  3. Olympus 850SW Battery Replacement: 步骤 3 中的图像 1,3 Olympus 850SW Battery Replacement: 步骤 3 中的图像 2,3 Olympus 850SW Battery Replacement: 步骤 3 中的图像 3,3
    • Find the arrows on the compartment, remove the small black plastic piece, and release the latch.
  4. Olympus 850SW Battery Replacement: 步骤 4 中的图像 1,1
    • Allow the latch to completely open and insert the battery, with the writing side up.
    • The battery slot is the bigger slot. The smaller slot is for the memory card.
  5. Olympus 850SW Battery Replacement: 步骤 5 中的图像 1,1
    • Close the latch. You will hear a click when the compartment is fully closed.
  6. Olympus 850SW Battery Replacement: 步骤 6 中的图像 1,1
    • Place the small black piece back in its' place.
  7. Olympus 850SW Battery Replacement: 步骤 7 中的图像 1,1
    • Place the metal cover back over the closed latch, and screw the screw back in.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 778
