简介
The X7R Marauder from Olight is a great flashlight. Unfortunately, the batteries are permanently installed and, according to the manufacturer, cannot be replaced by the user.
If your batteries go bad after the warranty has expired, you can use the following steps to replace the batteries in your Olight 7XR flashlight.
你所需要的
The three screws on the side can be loosened by a 0.9mm Allen key.
The cover can then be removed.
Reverse the steps to reassemble your device.
3等其他人完成本指南。
由衷感谢以下译者:
100%
Andrew S正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2条评论
what size allen key?
what size are the batteries?
ben senise - 回复
The allen key size is H0.9mm
The battery size is 18650.
Andrew S -
