跳转到主内容
修复你的物品
维修的权力
商店
生物医学
医疗设备
iFixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商有附属关系。
生物医学
简介
The air compressor is a very crucial component to the ventilator since it is responsible for delivering the filtered air from the machine to the breathing apparatus on the patient. This guide will help users to replace the air compressor from the main cart. Replacement is recommended if the air compressor is showing a lower pressure than normal.
For more information on replacing the compressor, please refer to page 9-31 (section 9.7) in the technical manual.
  1. Ensure the device is powered off and unplugged
    • Ensure the device is powered off and unplugged
    • Disconnect any wires or components that are plugged in prior to repair
  2. Tap the back end of a flat head screwdriver with a hammer to wedge the side trim pieces away from the machine.
    • Tap the back end of a flat head screwdriver with a hammer to wedge the side trim pieces away from the machine.
  3. Use the flat head screwdriver to pry off and remove the side panels
    • Use the flat head screwdriver to pry off and remove the side panels
    • When prying off the panels, do so carefully so that you do not to scratch or damage them
    • When reassembling the side panels, make sure that the connectors snap back into place.
    • Remove the mounting hardware from the compressor on the cart
  4. Screw in the service tool to assist in lifting the compressor and sliding out of the cart
    • Screw in the service tool to assist in lifting the compressor and sliding out of the cart
结论
Kobe Hayashi
于2020年02月07日注册
134 信誉积分
撰写一个指南
团队
Cal Poly, Team S7-G6, Paton Spring 2020 Cal Poly, Team S7-G6, Paton Spring 2020 的会员
CPSU-PATON-S20S7G6
3 名成员
创作了3篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 60
