跳转到主内容
Office Chair Gas Cylinder Replacement
你所需要的
  1. Office Chair Gas Cylinder Replacement, Gas Cylinder: 步骤 1 中的图像 1,1
    • Place the chair horizontally, putting it on its side.
  2. Office Chair Gas Cylinder Replacement: 步骤 2 中的图像 1,1
    • The base is connected to the chair either with retaining clips or nuts and bolts at its center.
    • Remove the retaining clips or unscrew the nuts and bolts with a wrench or drill.
    • Remove the base of the chair.
  3. Office Chair Gas Cylinder Replacement: 步骤 3 中的图像 1,1
    • Place a pipe wrench on the gas cylinder, and spray it with WD-40 to lubricate it and make it easier to remove.
    • Twist and pull the wrench to loosen the cylinder and remove it from its place.
  4. Office Chair Gas Cylinder Replacement: 步骤 4 中的图像 1,1
    • Look up the chair's part number to find which gas cylinders are compatible with your chair.
  5. Office Chair Gas Cylinder Replacement: 步骤 5 中的图像 1,1
    • Be sure to follow the instructions for your specific gas cylinder, since installation procedures may vary.
    • Place the tapered part of the cylinder into the column and rotate it into place.
    • Reconnect the base of the chair.
    • Place the chair upright and adjust the chair to your preferred height. Test it out by sitting on it.
终点
Christian Phillip
于09/20/20注册
149 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 69
过去 30 天: 375
总计 8,846
