跳转到主内容
Oculus Touch Controllers (2nd generation) Battery Replacement
你所需要的
  1. Oculus Touch Controllers (2nd generation) Battery Replacement, Opening: 步骤 1 中的图像 1,1
    • Slide down the cover on the left or right side of your chosen controller.
  2. Oculus Touch Controllers (2nd generation) Battery Replacement, Taking out the battery: 步骤 2 中的图像 1,3 Oculus Touch Controllers (2nd generation) Battery Replacement, Taking out the battery: 步骤 2 中的图像 2,3 Oculus Touch Controllers (2nd generation) Battery Replacement, Taking out the battery: 步骤 2 中的图像 3,3
    • After opening, push forward the battery and lift it up while holding the ring on the controller with your other hand.
    • You can also use the top of the cover to push and lift the battery if you don't have an opening tool.
    • Recycle batteries properly.
结论
另外一个人完成了本指南。
Artem Ivat
于02/05/20注册
3,546 声望
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 36
总计 1,969
