跳转到主内容
加入维修社区 - 创建账户
Oculus Rift DK1 Control Box Buttons Replacement
你所需要的
    1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: 步骤 1 中的图像 1,3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: 步骤 1 中的图像 2,3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: 步骤 1 中的图像 3,3
      • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
      • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
      询问修复机器人
      添加评论
    2. Oculus Rift DK1 Control Box Buttons Replacement: 步骤 2 中的图像 1,3 Oculus Rift DK1 Control Box Buttons Replacement: 步骤 2 中的图像 2,3 Oculus Rift DK1 Control Box Buttons Replacement: 步骤 2 中的图像 3,3
      • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
      • You can now remove the bottom lid of the control box. It should come apart easily.
      询问修复机器人
      添加评论
    1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: 步骤 3 中的图像 1,3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: 步骤 3 中的图像 2,3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: 步骤 3 中的图像 3,3
      • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
      • When the DVI connector has cleared the casing, lift the motherboard.
      • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
      • When reassembling the device, ensure that all of the wires are clear of the buttons.
      询问修复机器人
      添加评论
    2. Oculus Rift DK1 Control Box Buttons Replacement: 步骤 4 中的图像 1,3 Oculus Rift DK1 Control Box Buttons Replacement: 步骤 4 中的图像 2,3 Oculus Rift DK1 Control Box Buttons Replacement: 步骤 4 中的图像 3,3
      • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
      • Do so for both of the wires attached to the motherboard.
      • Now fully separate the motherboard from the control box casing.
      询问修复机器人
      添加评论
    1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Buttons: 步骤 5 中的图像 1,1
      • You now have the motherboard separated from the control box.
      • Identify the buttons that are not working.
      询问修复机器人
      添加评论
    2. Oculus Rift DK1 Control Box Buttons Replacement, Desoldering Button: 步骤 6 中的图像 1,1
      • For each button that needs to be replaced, use a soldering iron and soldering braid to desolder the four metal points.
      • Be careful! Soldering iron is hot.
      询问修复机器人
      添加评论
    3. Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: 步骤 7 中的图像 1,2 Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: 步骤 7 中的图像 2,2
      在这个步骤中使用的工具:
      • Now that each button with issues is desoldered, use tweezers to grab each button and detach from the motherboard.
      • If the button does not come off easily, go back to the previous step and ensure each of the four metal points are properly desoldered.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Ross De Vito
于01/13/15注册
246 声望
创作了2篇指南
团队
Cal Poly, Team 70-5, Forte Winter 2015 Cal Poly, Team 70-5, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G5
4 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 981
