跳转到主内容
Oculus Rift CV1 Remote Button Replacement
你所需要的
  1. Oculus Rift CV1 Remote Button Replacement, Battery: 步骤 1 中的图像 1,3 Oculus Rift CV1 Remote Button Replacement, Battery: 步骤 1 中的图像 2,3 Oculus Rift CV1 Remote Button Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the back panel by firmly sliding it towards the strap.
  2. Oculus Rift CV1 Remote Button Replacement: 步骤 2 中的图像 1,3 Oculus Rift CV1 Remote Button Replacement: 步骤 2 中的图像 2,3 Oculus Rift CV1 Remote Button Replacement: 步骤 2 中的图像 3,3
    • Push down on the tab under the battery.
    • Firmly slide the battery away from you. The battery should unlatch from its previous position.
    • Once the battery is removed, release the tab.
  3. Oculus Rift CV1 Remote Button Replacement, Remote Button: 步骤 3 中的图像 1,1
    • Remove the four 4mm Phillips #000 screws from the back of the remote.
  4. Oculus Rift CV1 Remote Button Replacement: 步骤 4 中的图像 1,1
    • Gently lift the wrist strap to split the back panel into two.
  5. Oculus Rift CV1 Remote Button Replacement: 步骤 5 中的图像 1,2 Oculus Rift CV1 Remote Button Replacement: 步骤 5 中的图像 2,2
    • Gently peel off the top of the control board.
    • Be gentle, if the buttons fall off, try to keep them in the orientation that they were in.
    • If the large black button falls off, place it back into the shell by orienting the tabs on the button to match the holes on the shell.
  6. Oculus Rift CV1 Remote Button Replacement: 步骤 6 中的图像 1,1
    • Pull the old buttons off and replace them with the new ones.
结论
Christian Perry
于01/24/19注册
223 声望
创作了2篇指南
团队
Cal Poly, Team S18-G4, White Winter 2019 Cal Poly, Team S18-G4, White Winter 2019 的会员
CPSU-WHITE-W19S18G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 783
