跳转到主内容
Oculus Rift CV1 Facial Interface Replacement
你所需要的
  1. Oculus Rift CV1 Facial Interface Replacement, Facial Interface: 步骤 1 中的图像 1,1
    • Pull firmly from the top of the headset facial interface to remove the foam frame.
  2. Oculus Rift CV1 Facial Interface Replacement: 步骤 2 中的图像 1,1
    • Remove the six T3 4mm screws from the top and bottom edges of the case.
  3. Oculus Rift CV1 Facial Interface Replacement: 步骤 3 中的图像 1,1
    • Insert the spudger underneath the edge of the lens on the left or right side.
    • Slide the spudger upwards and around the edge of the frame to undo the tabs underneath.
    • Repeat for the other side of the frame.
  4. Oculus Rift CV1 Facial Interface Replacement: 步骤 4 中的图像 1,3 Oculus Rift CV1 Facial Interface Replacement: 步骤 4 中的图像 2,3 Oculus Rift CV1 Facial Interface Replacement: 步骤 4 中的图像 3,3
    • Lift up the frame to see a tab hidden underneath the lycra mesh along the edge of the lens.
    • Pull up on the tab with the spudger.
    • Repeat for the corresponding tab on the other lens.
  5. Oculus Rift CV1 Facial Interface Replacement: 步骤 5 中的图像 1,1
    • Lift up on the plastic frame around the lens.
    • Slide a finger around the inside edge, pulling outward from the center of the lens to release the other tabs.
    • Repeat for the frame on the other lens.
  6. Oculus Rift CV1 Facial Interface Replacement: 步骤 6 中的图像 1,1
    • Pull up along the outer frame.
    • Remove the facial interface.
结论
另外一个人完成了本指南。
Kyle Anderson
于01/24/19注册
226 声望
撰写一个指南
团队
Cal Poly, Team S18-G4, White Winter 2019 Cal Poly, Team S18-G4, White Winter 2019 的会员
CPSU-WHITE-W19S18G4
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 52
总计 5,172
