跳转到主内容
修复你的物品
维修的权力
商店
简介
If your SIM card has remained lodged in your device after removing the tray, this guide will show you how to access the stuck SIM card by partially disassembling the device. This disassembly process can also be used to access the main components like the battery and motherboard.
配件
没有特定配件。
  1. Unscrew 8 side screws (flat 2.4mm or dedicated torx), then 4 rear screws (hex 1.5mm).
    • Unscrew 8 side screws (flat 2.4mm or dedicated torx), then 4 rear screws (hex 1.5mm).
  2. Withdrawal of back of phone and unplugging of LED connector. Withdrawal of back of phone and unplugging of LED connector. Withdrawal of back of phone and unplugging of LED connector.
    • Withdrawal of back of phone and unplugging of LED connector.
  3. Unscrew  5 screws (philips #0) off of black support.
    • Unscrew 5 screws (philips #0) off of black support.
    • Withdrawal of black support
  4. Unscrew 3 screws (philips #0) maintening PCB.
    • Unscrew 3 screws (philips #0) maintening PCB.
    • Unplug antenna connector.
    • Unplug ZIF on the left.
    • Unplug ZIF on top.
    • Unplug the two bottom connectors.
  5. Remove the stuck SIM card. Remove the stuck SIM card.
    • Remove the stuck SIM card.
结论
2等其他人完成本指南。
Steve Muller
于2018年05月14日注册
178 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 8
总计 657
