跳转到主内容
OPPO N1 Rear Case Replacement
你所需要的
  1. OPPO N1 Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Rear Case Replacement: 步骤 2 中的图像 1,2 OPPO N1 Rear Case Replacement: 步骤 2 中的图像 2,2
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
结论
9等其他人完成本指南。
Max Pietsch
于09/26/14注册
753 声望
撰写一个指南
团队
USF Tampa, Team 13-5, Staggers Fall 2014 USF Tampa, Team 13-5, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G5
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 1,903
