跳转到主内容
OPPO N1 Motherboard Replacement
你所需要的
  1. OPPO N1 Motherboard Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Motherboard Replacement: 步骤 2 中的图像 1,2 OPPO N1 Motherboard Replacement: 步骤 2 中的图像 2,2
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. OPPO N1 Motherboard Replacement, Battery: 步骤 3 中的图像 1,2 OPPO N1 Motherboard Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
  4. OPPO N1 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use the tweezers or your fingers to remove the sliver plates.
  5. OPPO N1 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the black plate with your fingers.
  6. OPPO N1 Motherboard Replacement: 步骤 6 中的图像 1,3 OPPO N1 Motherboard Replacement: 步骤 6 中的图像 2,3 OPPO N1 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Use tweezers or your fingers to pull up the connector tabs.
  7. OPPO N1 Motherboard Replacement: 步骤 7 中的图像 1,2 OPPO N1 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
  8. OPPO N1 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Use tweezers or fingers to remove the three connector tabs.
  9. OPPO N1 Motherboard Replacement: 步骤 9 中的图像 1,2 OPPO N1 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Use tweezers or your fingers to remove the motherboard.
结论
8等其他人完成本指南。
Joshua Stone
于09/26/14注册
1,064 声望
创作了5篇指南
团队
USF Tampa, Team 13-5, Staggers Fall 2014 USF Tampa, Team 13-5, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G5
3 名成员
创作了8篇指南
3条评论
how much is the mother board for oppo f1
gillianrain28 - 回复
Hi,I used a wrong car charger on my oppo n1 in the wrong port and since then my phone went off and never turns on.
Can I I sent the unit to you for repair?
danjuma kolo - 回复
I used a round pin car charger at the earpiece port of my oppo n1…and the phone went off…tiok it for repair but still not working…can u be off assistance
danjuma kolo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 5,270
