简介
So I created this when I took this apart, mainly because I need to clean its dusty sockets filled with dust.
你所需要的
I get this in a university store....Yep, you are right. A university store.
This one was great for its price. It costs about 20$ and have all the function I need.
However, this thing probably run on the oldest USB 1.1 interface, so don't expect the transmission to be fast.
Still, you can plug in your music into the MIC plug and record it as a MP3 directly or a WMA.
Now, pop off the motherboard. There are three ports that hold it down, but avoid them is simple. Very simple, actually.
Do anyone know what those copper foil serve? They are soldered to the board so I didn't dare removing it. And, there is nothing interesting beneath...
Anyway, if you need to put it together, just reversely follow the steps (while looking for those foam-like sponge fills)
The device is simple, cheap and well-machined. The 2 GB internal storage also make it possible to fit in about 2000 minutes of Mp3. Good device to have. Easy to repair.
Well, if you are not using your phone for music...
2等其他人完成本指南。
3条评论
Got spit on my olympus vn 722 pc. Dried it out but now it's stuck on Hold. Any suggestions?
I think you should disassemble it and clean the switch throughly. The liquid might have got into it and shorted the contact.
Use an ultrasonic cleaner, if you have one. Otherwise soak in soap water (perhaps) for some time, and then soak in warm water a couple times to remove the soap.
