当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
Carefully lift the screen out.
Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
Rotate the top half of the laptop so that the back cover is facing you.
Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
Remove the back cover by gently lifting it off of the laptop.
When pulling out the connectors, make sure to hold the metal connector instead of the wire.
Gently pull out the two antenna connectors by pulling them away from the motherboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
