跳转到主内容
OLPC XO-4 Touch Screen Frame Replacement
你所需要的
  1. OLPC XO-4 Touch Screen Frame Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Screen Frame Replacement: 步骤 2 中的图像 1,2 OLPC XO-4 Touch Screen Frame Replacement: 步骤 2 中的图像 2,2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Screen Frame Replacement: 步骤 3 中的图像 1,2 OLPC XO-4 Touch Screen Frame Replacement: 步骤 3 中的图像 2,2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Screen Frame Replacement, Screen Frame: 步骤 4 中的图像 1,3 OLPC XO-4 Touch Screen Frame Replacement, Screen Frame: 步骤 4 中的图像 2,3 OLPC XO-4 Touch Screen Frame Replacement, Screen Frame: 步骤 4 中的图像 3,3
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Screen Frame Replacement: 步骤 5 中的图像 1,3 OLPC XO-4 Touch Screen Frame Replacement: 步骤 5 中的图像 2,3 OLPC XO-4 Touch Screen Frame Replacement: 步骤 5 中的图像 3,3
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Screen Frame Replacement: 步骤 6 中的图像 1,1
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Screen Frame Replacement: 步骤 7 中的图像 1,2 OLPC XO-4 Touch Screen Frame Replacement: 步骤 7 中的图像 2,2
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
结论
Ji Kim
于01/25/13注册
18 声望
创作了3篇指南
团队
Cal Poly, Team 3-29, Amido Winter 2013 Cal Poly, Team 3-29, Amido Winter 2013 的会员
CPSU-AMIDO-W13S3G29
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 211
