跳转到主内容
加入维修社区 - 创建账户
OLPC XO-4 Touch Power Button Replacement
你所需要的
    1. OLPC XO-4 Touch Power Button Replacement, Battery: 步骤 1 中的图像 1,1
      • Turn the laptop upside-down, with the handle facing away from you.
      询问修复机器人
      添加评论
    2. OLPC XO-4 Touch Power Button Replacement: 步骤 2 中的图像 1,2 OLPC XO-4 Touch Power Button Replacement: 步骤 2 中的图像 2,2
      • Pull the lock tabs towards the green outer edges of the laptop.
      • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
      询问修复机器人
      添加评论
    3. OLPC XO-4 Touch Power Button Replacement: 步骤 3 中的图像 1,2 OLPC XO-4 Touch Power Button Replacement: 步骤 3 中的图像 2,2
      • Lift up on the middle of the battery to remove it from the device.
      询问修复机器人
      添加评论
    1. OLPC XO-4 Touch Power Button Replacement, Screen Frame: 步骤 4 中的图像 1,3 OLPC XO-4 Touch Power Button Replacement, Screen Frame: 步骤 4 中的图像 2,3 OLPC XO-4 Touch Power Button Replacement, Screen Frame: 步骤 4 中的图像 3,3
      • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
      • Rotate the screen 180° and remove the other two screws.
      • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
      询问修复机器人
      添加评论
    2. OLPC XO-4 Touch Power Button Replacement: 步骤 5 中的图像 1,3 OLPC XO-4 Touch Power Button Replacement: 步骤 5 中的图像 2,3 OLPC XO-4 Touch Power Button Replacement: 步骤 5 中的图像 3,3
      • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
      • Repeat the step above for the panel on the other side.
      询问修复机器人
      添加评论
    3. OLPC XO-4 Touch Power Button Replacement: 步骤 6 中的图像 1,1
      • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
      • Gently lift up the lower part of the frame and pull it down to free the screen frame.
      询问修复机器人
      添加评论
    4. OLPC XO-4 Touch Power Button Replacement: 步骤 7 中的图像 1,2 OLPC XO-4 Touch Power Button Replacement: 步骤 7 中的图像 2,2
      • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
      询问修复机器人
      添加评论
    1. OLPC XO-4 Touch Power Button Replacement, Screen: 步骤 8 中的图像 1,1
      • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    2. OLPC XO-4 Touch Power Button Replacement: 步骤 9 中的图像 1,2 OLPC XO-4 Touch Power Button Replacement: 步骤 9 中的图像 2,2
      • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
      • Carefully lift the screen out.
      询问修复机器人
      添加评论
    3. OLPC XO-4 Touch Power Button Replacement: 步骤 10 中的图像 1,3 OLPC XO-4 Touch Power Button Replacement: 步骤 10 中的图像 2,3 OLPC XO-4 Touch Power Button Replacement: 步骤 10 中的图像 3,3
      • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
      • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
      询问修复机器人
      添加评论
    4. OLPC XO-4 Touch Power Button Replacement: 步骤 11 中的图像 1,1
      • Remove the screen from the laptop.
      询问修复机器人
      添加评论
    1. OLPC XO-4 Touch Power Button Replacement, Back Cover: 步骤 12 中的图像 1,1
      • Remove the four 6mm screws using a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    2. OLPC XO-4 Touch Power Button Replacement: 步骤 13 中的图像 1,2 OLPC XO-4 Touch Power Button Replacement: 步骤 13 中的图像 2,2
      • Rotate the top half of the laptop so that the back cover is facing you.
      • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
      • Remove the back cover by gently lifting it off of the laptop.
      询问修复机器人
      添加评论
    1. OLPC XO-4 Touch Power Button Replacement, Wireless Card: 步骤 14 中的图像 1,3 OLPC XO-4 Touch Power Button Replacement, Wireless Card: 步骤 14 中的图像 2,3 OLPC XO-4 Touch Power Button Replacement, Wireless Card: 步骤 14 中的图像 3,3
      • When pulling out the connectors, make sure to hold the metal connector instead of the wire.
      • Gently pull out the two antenna connectors by pulling them away from the motherboard.
      询问修复机器人
      添加评论
    2. OLPC XO-4 Touch Power Button Replacement: 步骤 15 中的图像 1,1
      • Remove the black 4mm Phillips #1 screw holding the wireless card in.
      询问修复机器人
      添加评论
    3. OLPC XO-4 Touch Power Button Replacement: 步骤 16 中的图像 1,2 OLPC XO-4 Touch Power Button Replacement: 步骤 16 中的图像 2,2
      • Remove the wireless card from the laptop by gently sliding it out of its socket.
      询问修复机器人
      添加评论
    1. OLPC XO-4 Touch Power Button Replacement, Motherboard: 步骤 17 中的图像 1,3 OLPC XO-4 Touch Power Button Replacement, Motherboard: 步骤 17 中的图像 2,3 OLPC XO-4 Touch Power Button Replacement, Motherboard: 步骤 17 中的图像 3,3
      • Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
      • Remove the metal cover from the laptop.
      询问修复机器人
      添加评论
    2. OLPC XO-4 Touch Power Button Replacement: 步骤 18 中的图像 1,3 OLPC XO-4 Touch Power Button Replacement: 步骤 18 中的图像 2,3 OLPC XO-4 Touch Power Button Replacement: 步骤 18 中的图像 3,3
      • Pull the connectors out by holding the plastic tabs and not the wires.
      • Unplug the three wires connecting the motherboard to the bottom half of the laptop.
      • Unplug the two speaker wires from the motherboard.
      询问修复机器人
      添加评论
    3. OLPC XO-4 Touch Power Button Replacement: 步骤 19 中的图像 1,3 OLPC XO-4 Touch Power Button Replacement: 步骤 19 中的图像 2,3 OLPC XO-4 Touch Power Button Replacement: 步骤 19 中的图像 3,3
      • Turn the device over to where the screen used to be.
      • Pull out ribbon cable by holding the purple plastic tab.
      • Pull out connector with the black and white wire by holding plastic tab.
      询问修复机器人
      添加评论
    4. OLPC XO-4 Touch Power Button Replacement: 步骤 20 中的图像 1,2 OLPC XO-4 Touch Power Button Replacement: 步骤 20 中的图像 2,2
      • Move the motherboard slightly to the left so that the audio input and output jacks are out of the frame.
      • Pull the motherboard out of the laptop.
      询问修复机器人
      添加评论
    1. OLPC XO-4 Touch Power Button Replacement, Power Button: 步骤 21 中的图像 1,2 OLPC XO-4 Touch Power Button Replacement, Power Button: 步骤 21 中的图像 2,2
      • Remove the power button by pinching in the four tabs until the power button can be pushed out.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 3-29, Amido Winter 2013 Cal Poly, Team 3-29, Amido Winter 2013 的会员
CPSU-AMIDO-W13S3G29
4 名成员
创作了70篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 27
总计 633
