当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
Gently lift up on the back of the keyboard.
Pull the keyboard up far enough to expose the ribbon cable.
Gently lift up on the black connector to release the ribbon cable.
Gently pull the blue plastic tab up and away from the black connector.
Remove the keyboard from the laptop.
Flip the laptop over, showing the top of the device.
Open the laptop and rotate the screen ninety degrees.
Tilt the screen so the lower right corner of the screen is closer to the lower case.
Be careful not to pull the bottom portion of the laptop completely off, as there is a cable connecting it to the laptop.
Slide the green trim pieces away from the screen.
This should release the entire bottom portion of the laptop.
Rotate the entire lower assembly up slightly, and pull it away from the screen to free it from the screen hinge.
There may be some adhesive holding the cable to the metal plate. Gently pull the cable off of the plate if it is stuck.
You should now be looking at the bottom of the lower case.
Remove the eight 4mm Phillips #1 screws attaching the green trim pieces to the lower frame.
Pry off the front and side trim pieces.
Disconnect the ribbon cable attached to the keyboard compartment.
Unplug the ribbon cable between the touchpad and the mouse buttons controller.
Remove the mouse buttons controller from the device.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
