本指南有最近更改,您可查看未经巡查的最新版本。
简介
Learn how to replace the motherboard on the OLPC XO-4 Touch.
你所需要的
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
Gently pull out the two antenna connectors by pulling them away from the motherboard.
Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
Remove the metal cover from the laptop.
另外一个人完成了本指南。
