跳转到主内容
OLPC XO-4 Touch Motherboard Replacement
你所需要的
  1. OLPC XO-4 Touch Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Motherboard Replacement: 步骤 2 中的图像 1,2 OLPC XO-4 Touch Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Motherboard Replacement: 步骤 3 中的图像 1,2 OLPC XO-4 Touch Motherboard Replacement: 步骤 3 中的图像 2,2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Motherboard Replacement, Screen Frame: 步骤 4 中的图像 1,3 OLPC XO-4 Touch Motherboard Replacement, Screen Frame: 步骤 4 中的图像 2,3 OLPC XO-4 Touch Motherboard Replacement, Screen Frame: 步骤 4 中的图像 3,3
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Motherboard Replacement: 步骤 5 中的图像 1,3 OLPC XO-4 Touch Motherboard Replacement: 步骤 5 中的图像 2,3 OLPC XO-4 Touch Motherboard Replacement: 步骤 5 中的图像 3,3
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Motherboard Replacement: 步骤 6 中的图像 1,1
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Motherboard Replacement: 步骤 7 中的图像 1,2 OLPC XO-4 Touch Motherboard Replacement: 步骤 7 中的图像 2,2
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
  8. OLPC XO-4 Touch Motherboard Replacement, Screen: 步骤 8 中的图像 1,1
    • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
  9. OLPC XO-4 Touch Motherboard Replacement: 步骤 9 中的图像 1,2 OLPC XO-4 Touch Motherboard Replacement: 步骤 9 中的图像 2,2
    • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
    • Carefully lift the screen out.
  10. OLPC XO-4 Touch Motherboard Replacement: 步骤 10 中的图像 1,3 OLPC XO-4 Touch Motherboard Replacement: 步骤 10 中的图像 2,3 OLPC XO-4 Touch Motherboard Replacement: 步骤 10 中的图像 3,3
    • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
    • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
  11. OLPC XO-4 Touch Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the screen from the laptop.
  12. OLPC XO-4 Touch Motherboard Replacement, Back Cover: 步骤 12 中的图像 1,1
    • Remove the four 6mm screws using a Phillips #1 screwdriver.
  13. OLPC XO-4 Touch Motherboard Replacement: 步骤 13 中的图像 1,2 OLPC XO-4 Touch Motherboard Replacement: 步骤 13 中的图像 2,2
    • Rotate the top half of the laptop so that the back cover is facing you.
    • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
    • Remove the back cover by gently lifting it off of the laptop.
  14. OLPC XO-4 Touch Motherboard Replacement, Wireless Card: 步骤 14 中的图像 1,3 OLPC XO-4 Touch Motherboard Replacement, Wireless Card: 步骤 14 中的图像 2,3 OLPC XO-4 Touch Motherboard Replacement, Wireless Card: 步骤 14 中的图像 3,3
    • When pulling out the connectors, make sure to hold the metal connector instead of the wire.
    • Gently pull out the two antenna connectors by pulling them away from the motherboard.
  15. OLPC XO-4 Touch Motherboard Replacement: 步骤 15 中的图像 1,1
    • Remove the black 4mm Phillips #1 screw holding the wireless card in.
  16. OLPC XO-4 Touch Motherboard Replacement: 步骤 16 中的图像 1,2 OLPC XO-4 Touch Motherboard Replacement: 步骤 16 中的图像 2,2
    • Remove the wireless card from the laptop by gently sliding it out of its socket.
  17. OLPC XO-4 Touch Motherboard Replacement, Motherboard: 步骤 17 中的图像 1,3 OLPC XO-4 Touch Motherboard Replacement, Motherboard: 步骤 17 中的图像 2,3 OLPC XO-4 Touch Motherboard Replacement, Motherboard: 步骤 17 中的图像 3,3
    • Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
    • Remove the metal cover from the laptop.
  18. OLPC XO-4 Touch Motherboard Replacement: 步骤 18 中的图像 1,3 OLPC XO-4 Touch Motherboard Replacement: 步骤 18 中的图像 2,3 OLPC XO-4 Touch Motherboard Replacement: 步骤 18 中的图像 3,3
    • Pull the connectors out by holding the plastic tabs and not the wires.
    • Unplug the three wires connecting the motherboard to the bottom half of the laptop.
    • Unplug the two speaker wires from the motherboard.
  19. OLPC XO-4 Touch Motherboard Replacement: 步骤 19 中的图像 1,3 OLPC XO-4 Touch Motherboard Replacement: 步骤 19 中的图像 2,3 OLPC XO-4 Touch Motherboard Replacement: 步骤 19 中的图像 3,3
    • Turn the device over to where the screen used to be.
    • Pull out ribbon cable by holding the purple plastic tab.
    • Pull out connector with the black and white wire by holding plastic tab.
  20. OLPC XO-4 Touch Motherboard Replacement: 步骤 20 中的图像 1,2 OLPC XO-4 Touch Motherboard Replacement: 步骤 20 中的图像 2,2
    • Move the motherboard slightly to the left so that the audio input and output jacks are out of the frame.
    • Pull the motherboard out of the laptop.
结论
另外一个人完成了本指南。
Ji Kim
于01/25/13注册
18 声望
创作了3篇指南
团队
Cal Poly, Team 3-29, Amido Winter 2013 Cal Poly, Team 3-29, Amido Winter 2013 的会员
CPSU-AMIDO-W13S3G29
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 497
