本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will show you how to remove the microphone from your OLPC X0 4 Touch. The microphone records sound into the laptop.
你所需要的
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
Remove the metal cover from the laptop.
Locate the microphone on the front side of the laptop.
Gently, pull the microphone out of its socket.
即将完成!
结论
