跳转到主内容
OLPC XO-4 Touch Keyboard Replacement
你所需要的
  1. OLPC XO-4 Touch Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Keyboard Replacement: 步骤 2 中的图像 1,2 OLPC XO-4 Touch Keyboard Replacement: 步骤 2 中的图像 2,2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Keyboard Replacement: 步骤 3 中的图像 1,2 OLPC XO-4 Touch Keyboard Replacement: 步骤 3 中的图像 2,2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 OLPC XO-4 Touch Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
  5. OLPC XO-4 Touch Keyboard Replacement: 步骤 5 中的图像 1,3 OLPC XO-4 Touch Keyboard Replacement: 步骤 5 中的图像 2,3 OLPC XO-4 Touch Keyboard Replacement: 步骤 5 中的图像 3,3
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
  6. OLPC XO-4 Touch Keyboard Replacement: 步骤 6 中的图像 1,2 OLPC XO-4 Touch Keyboard Replacement: 步骤 6 中的图像 2,2
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
  7. OLPC XO-4 Touch Keyboard Replacement: 步骤 7 中的图像 1,2 OLPC XO-4 Touch Keyboard Replacement: 步骤 7 中的图像 2,2
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 3-30, Amido Winter 2013 Cal Poly, Team 3-30, Amido Winter 2013 的会员
CPSU-AMIDO-W13S3G30
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 876
