当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Slide the tabs out, towards the green edges, to show the open lock symbol.
The right tab will stay in place, but the left tab must be held in position while you remove the battery.
Turn the laptop so it is resting on its bottom.
Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop.
Rotate the top half of the laptop about 90 degrees.
Turn the laptop upside down, so you can see the screws on the bottom of the top half.
Remove the two 4mm screws with a Phillips #1 screwdriver.
Rotate the top half 180 degrees.
Rotate the top of the laptop 90 degrees, so that it is facing you again.
Slide the green pieces off the device. They should come off easily.
Unscrew the four 7.62mm Phillips #1 screws on either side of the screen.
The screen is still connected by ribbon cables. You can damage the cables if you remove the screen before disconnecting the cables.
Move the screen down a little to expose the ribbon cables.
Flip up the smaller tab under the left side of the screen.
Remove the small cable to separate the screen from the rest of the laptop.
Gently remove the screen.
Close the lid and rotate the device 180°.
Press firmly on the top two corners of the outside cover. Then slide it down, away from the antennas.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
