当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Slide the tabs out, towards the green edges, to show the open lock symbol.
The right tab will stay in place, but the left tab must be held in position while you remove the battery.
Turn the laptop so that the red XO symbol is right side up.
Pull off the white plastic panel with your fingers. There will be 4 tabs that hold the white panel in place. It will require moderate force to remove.
If you are having difficulty pulling off the white plastic panel, use a spudger.
Rotate the laptop 180 degrees so that the XO logo is now upside down.
Remove the center part of green handle. Push the white plastic back cover down away from the keyboard and top half. This should separate easily from the rest of the device.
Turn the laptop upside down, exposing the bottom inside of the keyboard.
This is similar to how the laptop was positioned when removing the battery, except now the white panel is gone.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
