跳转到主内容
OLPC XO-1.5 Screen Portion Replacement
你所需要的
  1. OLPC XO-1.5 Screen Portion Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the laptop upside down with the handle away from you.
  2. OLPC XO-1.5 Screen Portion Replacement: 步骤 2 中的图像 1,1
    • Slide the tabs out, towards the green edges, to show the open lock symbol.
    • The right tab will stay in place, but the left tab must be held in position while you remove the battery.
  3. OLPC XO-1.5 Screen Portion Replacement: 步骤 3 中的图像 1,3 OLPC XO-1.5 Screen Portion Replacement: 步骤 3 中的图像 2,3 OLPC XO-1.5 Screen Portion Replacement: 步骤 3 中的图像 3,3
    • Lift the middle of the battery to remove it.
  4. OLPC XO-1.5 Screen Portion Replacement, Screen Portion: 步骤 4 中的图像 1,1
    • Using the Phillips screwdriver, unscrew the 5 size M2 x .4 x 4mm screws underneath the battery.
  5. OLPC XO-1.5 Screen Portion Replacement: 步骤 5 中的图像 1,1
    • Turn the laptop so that the red XO symbol is right side up.
    • Pull off the white plastic panel with your fingers. There will be 4 tabs that hold the white panel in place. It will require moderate force to remove.
    • If you are having difficulty pulling off the white plastic panel, use a spudger.
  6. OLPC XO-1.5 Screen Portion Replacement: 步骤 6 中的图像 1,1
    • Unscrew the 4 size M2 x .4 x 4mm screws that are connected to the green plastic.
  7. OLPC XO-1.5 Screen Portion Replacement: 步骤 7 中的图像 1,1
    • Unplug the white connector with black cables on each end on the left of the hinge.
  8. OLPC XO-1.5 Screen Portion Replacement: 步骤 8 中的图像 1,1
    • Using the Phillips screwdriver, unscrew the 4 size M3 x .5 x 5mm screws holding the metal to the rest of the laptop.
  9. OLPC XO-1.5 Screen Portion Replacement: 步骤 9 中的图像 1,1
    • Carefully lift the top half that has the screen away from the bottom half.
    • There is still one black cable connecting the two halves. Be sure not to break it.
  10. OLPC XO-1.5 Screen Portion Replacement: 步骤 10 中的图像 1,2 OLPC XO-1.5 Screen Portion Replacement: 步骤 10 中的图像 2,2
    • Rotate the laptop 180 degrees so that the XO logo is now upside down.
    • Remove the center part of green handle. Push the white plastic back cover down away from the keyboard and top half. This should separate easily from the rest of the device.
  11. OLPC XO-1.5 Screen Portion Replacement: 步骤 11 中的图像 1,1
    • Turn the laptop upside down, exposing the bottom inside of the keyboard.
    • This is similar to how the laptop was positioned when removing the battery, except now the white panel is gone.
  12. OLPC XO-1.5 Screen Portion Replacement: 步骤 12 中的图像 1,1
    • Slide the black cable (the one that holds the two halves together) out of its connector.
  13. OLPC XO-1.5 Screen Portion Replacement: 步骤 13 中的图像 1,2 OLPC XO-1.5 Screen Portion Replacement: 步骤 13 中的图像 2,2
    • Separate the screen portion from the rest of the laptop.
结论
2等其他人完成本指南。
Sam Clark
于10/05/12注册
61 声望
撰写一个指南
团队
Cal Poly, Team 3-19, Amido Fall 2012 Cal Poly, Team 3-19, Amido Fall 2012 的会员
CPSU-AMIDO-F12S3G19
6 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,049
