本指南有最近更改,您可查看未经巡查的最新版本。
简介
If your OLPC does not turn on, the physical power button may be damaged. Use this guide to replace a broken or faulty power button.
你所需要的
Turn the laptop so it is resting on its bottom.
Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop.
Rotate the top half of the laptop about 90 degrees.
Disconnect the five cables that connect the motherboard to the case by pulling them straight out of their sockets.
Push the four power button retaining clips through the bottom of the case with the tip of a screwdriver.
