跳转到主内容
Nvidia Shield Tablet Speaker Replacement
你所需要的
  1. Nvidia Shield Tablet Speaker Replacement, Rear Case: 步骤 1 中的图像 1,2 Nvidia Shield Tablet Speaker Replacement, Rear Case: 步骤 1 中的图像 2,2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Speaker Replacement: 步骤 2 中的图像 1,3 Nvidia Shield Tablet Speaker Replacement: 步骤 2 中的图像 2,3 Nvidia Shield Tablet Speaker Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.16
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Speaker Replacement: 步骤 3 中的图像 1,2 Nvidia Shield Tablet Speaker Replacement: 步骤 3 中的图像 2,2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • Orient your tablet so that the top of the tablet is furthest away from you.
    • Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
  5. Nvidia Shield Tablet Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the two 3.0 mm Phillips #00 screws securing the speaker.
  6. Nvidia Shield Tablet Speaker Replacement: 步骤 6 中的图像 1,3 Nvidia Shield Tablet Speaker Replacement: 步骤 6 中的图像 2,3 Nvidia Shield Tablet Speaker Replacement: 步骤 6 中的图像 3,3
    • Gently pry the speaker up with the flat end of a spudger.
    • Use a plastic opening tool to peel up the tape covering the speaker wire.
  7. Nvidia Shield Tablet Speaker Replacement: 步骤 7 中的图像 1,2 Nvidia Shield Tablet Speaker Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    $7.16
    • Next, with a gentle but firm grip, pull the audio input ribbon with the precision tweezers.
    • Finally, unplug the power source from your speaker using the precision tweezers.
    • Make sure you are using your anti-static wrist strap.
结论
另外一个人完成了本指南。
Molly Bauer
于08/27/15注册
1,478 声望
创作了6篇指南
团队
USF Tampa, Team 2-2, Blackwell Fall 2015 USF Tampa, Team 2-2, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S2G2
3 名成员
创作了11篇指南
1指南评论
This didn't work
Riley Schork - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 2,793
