跳转到主内容
Nvidia Shield Tablet Motherboard Replacement
你所需要的
  1. Nvidia Shield Tablet Motherboard Replacement, Rear Case: 步骤 1 中的图像 1,2 Nvidia Shield Tablet Motherboard Replacement, Rear Case: 步骤 1 中的图像 2,2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Motherboard Replacement: 步骤 2 中的图像 1,3 Nvidia Shield Tablet Motherboard Replacement: 步骤 2 中的图像 2,3 Nvidia Shield Tablet Motherboard Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.16
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Motherboard Replacement: 步骤 3 中的图像 1,2 Nvidia Shield Tablet Motherboard Replacement: 步骤 3 中的图像 2,2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    $7.16
    • Carefully use the precision tweezers to unplug the ribbon cable.
    • Be sure to have your anti-static wrist strap on for this procedure.
  5. Nvidia Shield Tablet Motherboard Replacement: 步骤 5 中的图像 1,3 Nvidia Shield Tablet Motherboard Replacement: 步骤 5 中的图像 2,3 Nvidia Shield Tablet Motherboard Replacement: 步骤 5 中的图像 3,3
    • Remove the two 6.5 mm Phillips #00 screws and seven 3.0 mm Phillips #00 screws.
  6. Nvidia Shield Tablet Motherboard Replacement: 步骤 6 中的图像 1,3 Nvidia Shield Tablet Motherboard Replacement: 步骤 6 中的图像 2,3 Nvidia Shield Tablet Motherboard Replacement: 步骤 6 中的图像 3,3
    • Use a pair of tweezers to disconnect the three black antenna cables from the motherboard.
    • Use the flat end of the spudger tool to carefully pry up the motherboard.
    • In the first Shield, the stylus ribbon cable is located under the right side of board. While there are 2 additional cables for the cameras underneath the left end of the board. Be sure to loosen the cameras before lifting the board.
  7. Nvidia Shield Tablet Motherboard Replacement: 步骤 7 中的图像 1,2 Nvidia Shield Tablet Motherboard Replacement: 步骤 7 中的图像 2,2
    • Desolder the positive and negative battery cables from the motherboard.
    • Make sure to note which wire goes where, you don't want to re-solder the wires backwards!
    • The motherboard should now come free.
结论
6等其他人完成本指南。
Molly Bauer
于08/27/15注册
1,478 声望
创作了6篇指南
团队
USF Tampa, Team 2-2, Blackwell Fall 2015 USF Tampa, Team 2-2, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S2G2
3 名成员
创作了11篇指南
9指南评论
Where do you obtain a new motherboard?
imprintcave - 回复
The real question is more about how to find a new shield tablet motherboard ??
willixlive - 回复
where can i buy the motherboard
Gurjot Dhaliwal - 回复
waar kan ik een nieuw shield moederbord kopen?
tom1vangestel - 回复
Hello, I'm looking for a description of the various ribbon connectors on the motherboard.
I'm also looking for a hint to solve a problem I have after replacing the screen+digitizer: the right side (half) of the touch screen does'n work.
Laurent Zanoni - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 32
总计 9,813
