跳转到主内容
Nvidia Shield TV 1st Generation I/O Board Replacement
你所需要的
  1. Nvidia Shield TV 1st Generation I/O Board Replacement, I/O Board: 步骤 1 中的图像 1,1
    • Flip the device over and use a plastic opening tool to remove the bottom cover.
  2. Nvidia Shield TV 1st Generation I/O Board Replacement: 步骤 2 中的图像 1,2 Nvidia Shield TV 1st Generation I/O Board Replacement: 步骤 2 中的图像 2,2
    • Remove the indicated cables and ribbon wires.
  3. Nvidia Shield TV 1st Generation I/O Board Replacement: 步骤 3 中的图像 1,2 Nvidia Shield TV 1st Generation I/O Board Replacement: 步骤 3 中的图像 2,2
    • Remove the indicated four screws using the T6 Torx screwdriver.
  4. Nvidia Shield TV 1st Generation I/O Board Replacement: 步骤 4 中的图像 1,1
    • Carefully tilt and pull out the I/O board from the device.
结论
3等其他人完成本指南。
Joshua Neally
于09/25/17注册
581 声望
创作了4篇指南
团队
USF Tampa, Team S16-G6, Eyestone Fall 2017 USF Tampa, Team S16-G6, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S16G6
3 名成员
创作了7篇指南
4条评论
where do i get a new I/O Board ?
Max Eschbach (SAVAGE) - 回复
Yaaa, where can we get the I/O board? :-D
VashCZ - 回复
Yes, i need a replacement I/O board too, where can I find one?
Anand Dhungav - 回复
Where can I get a replacement I/O board? What good are instructions without any availability for parts?
Mike - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 23
总计 3,860
