跳转到主内容
Nvidia Shield TV 1st Generation Hard Drive Replacement
你所需要的
  1. Nvidia Shield TV 1st Generation Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Flip the device over and use a plastic opening tool to remove the bottom cover.
  2. Nvidia Shield TV 1st Generation Hard Drive Replacement: 步骤 2 中的图像 1,3 Nvidia Shield TV 1st Generation Hard Drive Replacement: 步骤 2 中的图像 2,3 Nvidia Shield TV 1st Generation Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the tape that is covering the hard drive.
    • Place tape aside in a safe place so it can be reused to secure the hard drive when reassembling.
  3. Nvidia Shield TV 1st Generation Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the indicated screw using the T6 Torx Screwdriver.
  4. Nvidia Shield TV 1st Generation Hard Drive Replacement: 步骤 4 中的图像 1,2 Nvidia Shield TV 1st Generation Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Gently pull out the hard drive.
    • Remove the connector pins from the hard drive.
结论
5等其他人完成本指南。
Joshua Neally
于09/25/17注册
581 声望
创作了4篇指南
团队
USF Tampa, Team S16-G6, Eyestone Fall 2017 USF Tampa, Team S16-G6, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S16G6
3 名成员
创作了7篇指南
7条评论
How can I get a replacement sata cable? My tore when trying to replace with ssd.
3_D - 回复
This guide completely skips over the details on how to disconnect the cables. This is by far the trickiest part of this operation. The fact that the commenter above tore his SATA cable is proof that crucial steps of this procedure are missing!
ctphillips - 回复
This Fails to Mention The lower end version of the Nvidia Shield Console(16GB Storage) Is missing the cable that goes to the HDD and even the and even the soldering mounts to put a HDD in a 16GB version.
-B
Rob Craig - 回复
The part that is connected to the Sata connector for the HD with the ribbon attached how do I get a replacement one please
Steve Roe - 回复
How on earth do you disconnect the flat SATA cable from the motherboard safely?
Tobias Biehl - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 83
总计 8,823
