跳转到主内容
加入维修社区 - 创建账户
Nvidia Shield TV 1st Generation Controller Battery Replacement
你所需要的
    1. Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: 步骤 1 中的图像 1,2 Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: 步骤 1 中的图像 2,2
      • Remove the indicated six screws using the T6 Torx screwdriver.
      询问修复机器人
      添加评论
    2. Nvidia Shield TV 1st Generation Controller Battery Replacement: 步骤 2 中的图像 1,2 Nvidia Shield TV 1st Generation Controller Battery Replacement: 步骤 2 中的图像 2,2
      • Use the plastic opening tool to pry the face of the controller away from the body.
      • Make sure the controller is face down during this step as the buttons can easily fall out.
      询问修复机器人
      添加评论
    3. Nvidia Shield TV 1st Generation Controller Battery Replacement: 步骤 3 中的图像 1,1
      • Carefully remove the indicated ribbon wires from the face of the controller.
      添加评论
    4. Nvidia Shield TV 1st Generation Controller Battery Replacement: 步骤 4 中的图像 1,2 Nvidia Shield TV 1st Generation Controller Battery Replacement: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      $3.99
      • Use the angled tweezers to remove the vibration motor cable, moving it upward from its socket.
      • Lift the vibration motor out of the front case.
      • Repeat for the other side.
      • Use the angled tweezers to remove the battery cable, moving it upward from its socket.
      询问修复机器人
      添加评论
    5. Nvidia Shield TV 1st Generation Controller Battery Replacement: 步骤 5 中的图像 1,3 Nvidia Shield TV 1st Generation Controller Battery Replacement: 步骤 5 中的图像 2,3 Nvidia Shield TV 1st Generation Controller Battery Replacement: 步骤 5 中的图像 3,3
      • Using the T6 Torx screwdriver, remove the indicated eight screws from the logic board.
      • Lift the logic board away from the front case.
      添加评论
    6. Nvidia Shield TV 1st Generation Controller Battery Replacement: 步骤 6 中的图像 1,3 Nvidia Shield TV 1st Generation Controller Battery Replacement: 步骤 6 中的图像 2,3 Nvidia Shield TV 1st Generation Controller Battery Replacement: 步骤 6 中的图像 3,3
      • Using the T6 Torx screwdriver, remove the indicated four screws from the panel.
      • Remove the panel from the front case.
      • Lift the battery from the front case to remove it.
      添加评论
结论
取消:我没有完成这个指南。
12等其他人完成本指南。
团队
USF Tampa, Team S16-G6, Eyestone Fall 2017 USF Tampa, Team S16-G6, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S16G6
3 名成员
创作了14篇指南
8指南评论
Where can i buy the replacement Battery? What tags should i use to find it?
Rancid 3000a - 回复 分享
LC18650 Remote Control accu
djcornelissen - 回复 分享
Are battery packs available for the 2017 controller?
Andrew - 回复 分享
Simply reconnecting the battery fixed my issues
Charles Keisler - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 67
总计 21,697
