跳转到主内容
Nvidia Shield Pro Android TV Motherboard Replacement
你所需要的
  1. Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Use a plastic opening tool to pry open the front panel.
  2. Nvidia Shield Pro Android TV Motherboard Replacement: 步骤 2 中的图像 1,3 Nvidia Shield Pro Android TV Motherboard Replacement: 步骤 2 中的图像 2,3 Nvidia Shield Pro Android TV Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use a Torx TR6 screwdriver to remove the five 6mm screws that are securing the fan.
    • Unplug the power supply connected to the fan.
  3. Nvidia Shield Pro Android TV Motherboard Replacement: 步骤 3 中的图像 1,2 Nvidia Shield Pro Android TV Motherboard Replacement: 步骤 3 中的图像 2,2
    • Unplug the two black cable bundles that are running over the motherboard.
  4. Nvidia Shield Pro Android TV Motherboard Replacement: 步骤 4 中的图像 1,3 Nvidia Shield Pro Android TV Motherboard Replacement: 步骤 4 中的图像 2,3 Nvidia Shield Pro Android TV Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use a Torx TR6 screwdriver to remove the three 5mm screws securing the motherboard.
    • Detach the black and white coaxial cables from the motherboard.
    • Lift the motherboard out of the device and disconnect the black cable bundle.
结论
2等其他人完成本指南。
1指南评论
Please update the title of this to specify which model year Shield Pro it is for. I was looking for the 2019 model instructions and this obviously isn't that.
Thanks!
jkr4m3r - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 26
过去 30 天: 96
总计 3,735
