跳转到主内容
加入维修社区 - 创建账户
Nvidia Shield Pro Android TV I/O Board Replacement
你所需要的
    1. Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: 步骤 1 中的图像 2,2
      • Flip to the back side of your Nvidia Shield Pro Android TV.
      • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
      • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
      询问修复机器人
      添加评论
    1. Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: 步骤 2 中的图像 1,3 Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: 步骤 2 中的图像 2,3 Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: 步骤 2 中的图像 3,3
      • Remove the two pieces of adhesives found at the top and the bottom side of the hard drive.
      • Put the two adhesives aside. Make sure to keep them flat so that you can put them back on after.
      询问修复机器人
      添加评论
    2. Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 3 中的图像 1,3 Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 3 中的图像 2,3 Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 3 中的图像 3,3
      • Detach the pack of wires by pulling it away from the socket.
      询问修复机器人
      添加评论
    3. Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 4 中的图像 1,3 Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 4 中的图像 2,3 Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 4 中的图像 3,3
      • Next to the empty socket where the black wires were attached to the I/O board (refer back to Step 2), detach the plastic strap from the I/O board by pushing the strap away from the socket using your finger.
      添加评论
    4. Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 5 中的图像 1,2 Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 5 中的图像 2,2
      • Remove the screw on the metal piece using a T6 Torx screwdriver and put away the metal piece after removing the screw.
      询问修复机器人
      添加评论
    5. Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 6 中的图像 1,1
      • Gently pull the hard drive out of the device.
      添加评论
    1. Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: 步骤 7 中的图像 1,3 Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: 步骤 7 中的图像 2,3 Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: 步骤 7 中的图像 3,3
      • Detach the brown side of the connector from the I/O board by pulling it upward.
      • Remove the screw from the silver plate using a T6 Torx screwdriver.
      • Put the cable aside after removing it.
      询问修复机器人
      添加评论
    2. Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 8 中的图像 1,2 Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 8 中的图像 2,2
      • Detach the small bundle of black wires from the I/O board by gently pulling upward.
      • Be very gentle because the wires are very fragile.
      添加评论
    3. Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 9 中的图像 1,2 Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 9 中的图像 2,2
      • Remove the three T6 Torx screws from the I/O board.
      询问修复机器人
      添加评论
    4. Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 10 中的图像 1,3 Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 10 中的图像 2,3 Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 10 中的图像 3,3
      • Detach the multi-colored (red/yellow/black) wire from the I/O board by pulling it away from the socket.
      询问修复机器人
      添加评论
    5. Nvidia Shield Pro Android TV I/O Board Replacement: 步骤 11 中的图像 1,1
      • Gently remove the I/O board by sliding it away from the exterior input/output sockets on your Nvidia Shield Pro.
      添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
Jimmy Chen
于01/23/20注册
753 声望
创作了3篇指南
团队
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 的会员
CPSU-WHITE-W20S18G2
4 名成员
创作了26篇指南
2指南评论
Where can I buy Nvidia Shield Pro Android TV I/O Board? Greentings from Brazil.
Sergio Santos - 回复 分享
Aniyone managed to get a source for this part, The IO board
Yoda Mann - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 35
过去 30 天: 140
总计 7,518
