跳转到主内容
Nvidia Shield Pro Android TV Controller Triggers Replacement
你所需要的
  1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: 步骤 1 中的图像 1,3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: 步骤 1 中的图像 2,3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: 步骤 1 中的图像 3,3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Triggers Replacement: 步骤 2 中的图像 1,1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Triggers Replacement: 步骤 3 中的图像 1,2 Nvidia Shield Pro Android TV Controller Triggers Replacement: 步骤 3 中的图像 2,2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Triggers Replacement: 步骤 4 中的图像 1,2 Nvidia Shield Pro Android TV Controller Triggers Replacement: 步骤 4 中的图像 2,2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Triggers Replacement: 步骤 5 中的图像 1,2 Nvidia Shield Pro Android TV Controller Triggers Replacement: 步骤 5 中的图像 2,2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: 步骤 6 中的图像 1,3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: 步骤 6 中的图像 2,3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: 步骤 6 中的图像 3,3
    • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
    • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
    • Gently lift the motherboard from the controller housing.
  7. Nvidia Shield Pro Android TV Controller Triggers Replacement: 步骤 7 中的图像 1,3 Nvidia Shield Pro Android TV Controller Triggers Replacement: 步骤 7 中的图像 2,3 Nvidia Shield Pro Android TV Controller Triggers Replacement: 步骤 7 中的图像 3,3
    • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
    • Carefully pull the trigger directly out of its socket.
结论
1指南评论
how do you put the shoulder buttons back in. They fell out when I was trying to replace the battery
demarko9999 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 519
