跳转到主内容
Nvidia Shield Pro Android TV Controller Thumbsticks Replacement
你所需要的
  1. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Thumbsticks: 步骤 1 中的图像 1,3 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Thumbsticks: 步骤 1 中的图像 2,3 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Thumbsticks: 步骤 1 中的图像 3,3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 步骤 2 中的图像 1,1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 步骤 3 中的图像 1,2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 步骤 3 中的图像 2,2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 步骤 4 中的图像 1,2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 步骤 4 中的图像 2,2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 步骤 5 中的图像 1,2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 步骤 5 中的图像 2,2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
结论
3等其他人完成本指南。
Ben Carrasco
于01/23/20注册
347 声望
创作了2篇指南
团队
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 的会员
CPSU-WHITE-W20S18G2
4 名成员
创作了14篇指南
3指南评论
Very good instructions that were very helpful. Do you have recommendations on which thumbsticks are the best since the shield seems to have wider and deeper ones? Thanks again for the guide.
Charles Brodie - 回复
Just wondering where would I be able to buy a thumbstick spare part to replace it.
xguyun - 回复
Thanks, very good post, and it could be very useful for me. Just wondering where would I be able to buy a spare part for this thumbstick to replace my broken one.
xguyun - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 33
总计 2,294
