跳转到主内容
Nvidia Shield Pro Android TV Controller Rumble Motor Replacement
你所需要的
  1. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: 步骤 1 中的图像 1,3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: 步骤 1 中的图像 2,3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: 步骤 1 中的图像 3,3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 步骤 2 中的图像 1,1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 步骤 3 中的图像 1,2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 步骤 3 中的图像 2,2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 步骤 4 中的图像 1,2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 步骤 4 中的图像 2,2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 步骤 5 中的图像 1,2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 步骤 5 中的图像 2,2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: 步骤 6 中的图像 1,3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: 步骤 6 中的图像 2,3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: 步骤 6 中的图像 3,3
    • Grip the plugs as close to their ports as possible and pull them directly up and out.
    • Lift the rumble motors up and out of the chassis.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 272
