跳转到主内容
Nvidia Shield Pro Android TV Bottom Cover Replacement
你所需要的
  1. Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
结论
团队
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 的会员
CPSU-WHITE-W20S18G2
4 名成员
创作了14篇指南
1指南评论
Hi, Shield Pro 2.
Remove 2 small cross head screws securing top cover to the back plate. Next you have to pry open the back edge and then slide the top cover forwards about 8mm away from the back plate to clear 3 catch points along each side.
S. Carter - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 29
过去 30 天: 86
总计 2,823
