跳转到主内容
NVIDIA SHIELD Portable Motherboard Replacement
你所需要的
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: 步骤 1 中的图像 1,3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: 步骤 1 中的图像 2,3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: 步骤 1 中的图像 3,3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
    Any hints at getting the center plastic screw cover out?
    Miles Raymond - 回复
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: 步骤 2 中的图像 1,2 NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: 步骤 2 中的图像 2,2
    • The green grill is not screwed in so it can be pulled right out.
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: 步骤 3 中的图像 1,3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: 步骤 3 中的图像 2,3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: 步骤 3 中的图像 3,3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: 步骤 4 中的图像 1,1
    • Pull the battery apparatus out once all cables are removed.
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: 步骤 5 中的图像 1,3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: 步骤 5 中的图像 2,3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: 步骤 5 中的图像 3,3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: 步骤 6 中的图像 1,3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: 步骤 6 中的图像 2,3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: 步骤 6 中的图像 3,3
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
结论
3等其他人完成本指南。
Marc Perez
于09/29/14注册
545 声望
创作了2篇指南
团队
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G1
4 名成员
创作了18篇指南
一条评论
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,802
