跳转到主内容
Nvidia Shield Joystick Replacement
你所需要的
  1. Nvidia Shield Joystick Replacement, Remove Front Panel: 步骤 1 中的图像 1,3 Nvidia Shield Joystick Replacement, Remove Front Panel: 步骤 1 中的图像 2,3 Nvidia Shield Joystick Replacement, Remove Front Panel: 步骤 1 中的图像 3,3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Joystick Replacement, Remove Green Grill: 步骤 2 中的图像 1,2 Nvidia Shield Joystick Replacement, Remove Green Grill: 步骤 2 中的图像 2,2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Joystick Replacement, Remove Battery Cables: 步骤 3 中的图像 1,3 Nvidia Shield Joystick Replacement, Remove Battery Cables: 步骤 3 中的图像 2,3 Nvidia Shield Joystick Replacement, Remove Battery Cables: 步骤 3 中的图像 3,3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Joystick Replacement, Remove Battery Apparatus: 步骤 4 中的图像 1,1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Joystick Replacement, Removing Fan: 步骤 5 中的图像 1,3 Nvidia Shield Joystick Replacement, Removing Fan: 步骤 5 中的图像 2,3 Nvidia Shield Joystick Replacement, Removing Fan: 步骤 5 中的图像 3,3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. Nvidia Shield Joystick Replacement, Removing Logic Board: 步骤 6 中的图像 1,3 Nvidia Shield Joystick Replacement, Removing Logic Board: 步骤 6 中的图像 2,3 Nvidia Shield Joystick Replacement, Removing Logic Board: 步骤 6 中的图像 3,3
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
  7. Nvidia Shield Joystick Replacement, Removing Joysticks: 步骤 7 中的图像 1,3 Nvidia Shield Joystick Replacement, Removing Joysticks: 步骤 7 中的图像 2,3 Nvidia Shield Joystick Replacement, Removing Joysticks: 步骤 7 中的图像 3,3
    • Unscrew the 3 6.5mm screws from the Joystick board
    • Unplug the ribbon attached on the right hand side of the board
    • Once removed, the Joystick board will lift from the panel, allowing replacement
    • The thumb-Sticks can be pulled off of the metal pegs for replacement.
结论
4等其他人完成本指南。
团队
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G1
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 35
总计 3,791
