跳转到主内容
Nvidia Shield Controller Buttons Replacement
你所需要的
  1. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: 步骤 1 中的图像 1,3 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: 步骤 1 中的图像 2,3 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: 步骤 1 中的图像 3,3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
    Any hints at getting the center plastic screw cover out?
    Miles Raymond - 回复
  2. Nvidia Shield Controller Buttons Replacement, Remove Green Grill: 步骤 2 中的图像 1,2 Nvidia Shield Controller Buttons Replacement, Remove Green Grill: 步骤 2 中的图像 2,2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: 步骤 3 中的图像 1,3 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: 步骤 3 中的图像 2,3 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: 步骤 3 中的图像 3,3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Controller Buttons Replacement, Remove Battery Apparatus: 步骤 4 中的图像 1,1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Controller Buttons Replacement, Removing Button Board: 步骤 5 中的图像 1,3 Nvidia Shield Controller Buttons Replacement, Removing Button Board: 步骤 5 中的图像 2,3 Nvidia Shield Controller Buttons Replacement, Removing Button Board: 步骤 5 中的图像 3,3
    • Remove seven 6.5 mm T5 torx screws from the button board.
    • Refer to the second image as some screws are not visible in the first image. One of these screws is covered by the orange ribbon.
    • Remove the button board.
结论
7等其他人完成本指南。
团队
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G1
4 名成员
创作了18篇指南
2条评论
From where can I get the buttons?
Chirag Khatri - 回复
Hey:) I am not sure
Knut Gunnar Walle - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 6,036
