跳转到主内容
Nvidia Shield Battery Assembly Replacement
你所需要的
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: 步骤 1 中的图像 1,3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: 步骤 1 中的图像 2,3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: 步骤 1 中的图像 3,3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
    Any hints at getting the center plastic screw cover out?
    Miles Raymond - 回复
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: 步骤 2 中的图像 1,2 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: 步骤 2 中的图像 2,2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: 步骤 3 中的图像 1,3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: 步骤 3 中的图像 2,3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: 步骤 3 中的图像 3,3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: 步骤 4 中的图像 1,1
    • Pull the battery apparatus out once all cables are removed.
结论
5等其他人完成本指南。
团队
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G1
4 名成员
创作了18篇指南
4条评论
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - 回复
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - 回复
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - 回复
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 38
总计 6,015
