跳转到主内容
Nvidia Shield Battery Assembly Replacement
你所需要的
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: 步骤 1 中的图像 1,3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: 步骤 1 中的图像 2,3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: 步骤 1 中的图像 3,3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: 步骤 2 中的图像 1,2 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: 步骤 2 中的图像 2,2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: 步骤 3 中的图像 1,3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: 步骤 3 中的图像 2,3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: 步骤 3 中的图像 3,3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: 步骤 4 中的图像 1,1
    • Pull the battery apparatus out once all cables are removed.
结论
5等其他人完成本指南。
团队
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G1
4 名成员
创作了18篇指南
4条评论
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - 回复
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - 回复
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - 回复
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 15
过去 30 天: 55
总计 5,727
