跳转到主内容
Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement
你所需要的
  1. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,2 Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement, Power Cord: 步骤 1 中的图像 2,2
    • Unscrew the screws from the base of the blender (These should be 5 gauge phillips head screws).
    • 2 of the screws will be star shaped rather than phillips head.
    • Remove the base plate.
  2. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement: 步骤 2 中的图像 1,2 Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement: 步骤 2 中的图像 2,2
    • Identify the red and black wires topped with white-clear caps.
    • Use pliers to squeeze the flattened part of both caps.
    • The black and red wires attached to the power cord should be loose and ready to pull out.
  3. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement: 步骤 3 中的图像 1,1
    • Replace the cord by slipping the new cord's black and red wires into the caps.
    • Pinch the middle of the cap back to the flattened position using the pliers.
结论
另外一个人完成了本指南。
Allie Decker
于09/26/17注册
125 声望
撰写一个指南
团队
Cal Poly, Team S7-G1, Banghart Fall 2017 Cal Poly, Team S7-G1, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S7G1
5 名成员
创作了6篇指南
2条评论
Como puedo extraer la parte donde sienta el vaso de mi licuadora ninja ct641
Memorex com - 回复
Como puedo extraer la base donde asienta el vaso de licuadora ninja ct641
Memorex com - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 48
总计 3,616
