跳转到主内容
Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement
你所需要的
  1. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement, Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: 步骤 1 中的图像 1,1
    • Turn blender upside down
  2. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 步骤 2 中的图像 1,2 Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove these six screws (0.5 inch 5 gauge phillip's head)
    • Note: 2 of the screws will be star shaped circled in blue
    • Lift the bottom panel off
  3. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Unscrew and remove these six phillip's screws. (0.5 inch 5 gauge phillips)
    • Note: The screws circled in blue are 1/8" longer and have a slightly different top than the rest. These are the only two screws that are different than the rest.
  4. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 步骤 4 中的图像 1,3 Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 步骤 4 中的图像 2,3 Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Insert pry tool in between the two plastic pieces to separate them
    • Move pry tool back and forth from right to left until the two pieces begin to separate as shown.
    • Pry the two pieces apart with your hands as shown in the picture to finish separating the pieces.
  5. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 步骤 5 中的图像 1,1
    • This completes the disassembly of the main body of the blender so you can continue to perform replacements on the internal parts.
  6. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Remove the phillip's screws from the motherboard.
  7. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Flip the motherboard over.
  8. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove any plugs from the motherboard.
  9. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Desolder wires and cords. Replace old motherboard with new one, and resolder wires and cords.
结论
2等其他人完成本指南。
Will Jones
于09/26/17注册
155 声望
撰写一个指南
团队
Cal Poly, Team S7-G1, Banghart Fall 2017 Cal Poly, Team S7-G1, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S7G1
5 名成员
创作了6篇指南
一条评论
Hello Will - thank you for that lesson. I am from Canada, going to CUBA and my Cuban friend needs the motherboard for a similar blender (BL 770-2.) Where do I buy one? Thanks.
Judith Falardeau - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 29
总计 1,124
