跳转到主内容
Nutri Ninja Ninja Blender Duo BL641 Fan Replacement
你所需要的
  1. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement, Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: 步骤 1 中的图像 1,1
    • Turn blender upside down
  2. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: 步骤 2 中的图像 1,2 Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: 步骤 2 中的图像 2,2
    • Remove these six screws (0.5 inch 5 gauge phillip's head)
    • Note: 2 of the screws will be star shaped circled in blue
    • Lift the bottom panel off
  3. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: 步骤 3 中的图像 1,1
    • Unscrew and remove these six phillip's screws. (0.5 inch 5 gauge phillips)
    • Note: The screws circled in blue are 1/8" longer and have a slightly different top than the rest. These are the only two screws that are different than the rest.
  4. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: 步骤 4 中的图像 1,3 Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: 步骤 4 中的图像 2,3 Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: 步骤 4 中的图像 3,3
    • Insert pry tool in between the two plastic pieces to separate them
    • Move pry tool back and forth from right to left until the two pieces begin to separate as shown.
    • Pry the two pieces apart with your hands as shown in the picture to finish separating the pieces.
  5. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: 步骤 5 中的图像 1,1
    • This completes the disassembly of the main body of the blender so you can continue to perform replacements on the internal parts.
  6. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement, Fan: 步骤 6 中的图像 1,1
    • Remove this hex nut with the adjustable wrench.
    • Be sure to hold the fan still GENTLY while unscrewing the nut so the bolt does not spin with the nut.
    • Fan may be a little sharp
  7. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: 步骤 7 中的图像 1,2 Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: 步骤 7 中的图像 2,2
    • Grab the washer with pliers and twist/pull it off of the threaded rod.
    • The washer is not threaded but has rubbery glue holding it to the threaded rod. This is why unscrewing as well as pulling is necessary.
  8. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: 步骤 8 中的图像 1,1
    • Grab the fan gently and pull it off
结论
To reassemble your device, follow these instructions in reverse order along with the body disassembly guide.
Nathan
于09/26/17注册
201 声望
创作了2篇指南
团队
Cal Poly, Team S7-G1, Banghart Fall 2017 Cal Poly, Team S7-G1, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S7G1
5 名成员
创作了6篇指南
2条评论
Buenas noches.
¿Cómo puedo comprar una tarjeta de esta licuadora?
Victor Sosa - 回复
Anyone know where I can get a replacement fan? Google isn't turning up anything for me. :-(
Jackie Grupe - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 30
总计 2,720
