跳转到主内容
Nutri Ninja Ninja Blender Duo BL641 Blade Replacement
你所需要的
  1. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: 步骤 1 中的图像 1,2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: 步骤 1 中的图像 2,2
    • Make sure blender is turned off.
    • Lift open the lid of blender by pressing the "Release" button and move to the side
  2. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: 步骤 2 中的图像 1,2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: 步骤 2 中的图像 2,2
    • Carefully Grab the top of the blade and pull upward with medium force.
    • The blade should slide out easily.
    • Do not touch the blades! Even when dull they can still cut you.
  3. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: 步骤 3 中的图像 1,2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: 步骤 3 中的图像 2,2
    • Carefully pick up the new blade and match the bottom star shaped opening to the star shaped protrusion from the blender.
  4. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: 步骤 4 中的图像 1,1
    • Slowly connect the two star shapes together and push down until it reaches the bottom.
结论
Now your blender can resume blending to perfection.
Charlotte
于09/26/17注册
101 声望
撰写一个指南
团队
Cal Poly, Team S7-G1, Banghart Fall 2017 Cal Poly, Team S7-G1, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S7G1
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 27
总计 3,203
