跳转到主内容
Nutri Ninja BL450 Cooling Vent Replacement
你所需要的
  1. Nutri Ninja BL450 Cooling Vent Replacement, Small Rubber Wheel: 步骤 1 中的图像 1,1
    • Remove the cup from the blender base.
  2. Nutri Ninja BL450 Cooling Vent Replacement: 步骤 2 中的图像 1,2 Nutri Ninja BL450 Cooling Vent Replacement: 步骤 2 中的图像 2,2
    • Turn the blender over and unscrew the three 14 mm screws holding the slotted base in place. These are Torx Security bits (TR9) on some units.
  3. Nutri Ninja BL450 Cooling Vent Replacement: 步骤 3 中的图像 1,3 Nutri Ninja BL450 Cooling Vent Replacement: 步骤 3 中的图像 2,3 Nutri Ninja BL450 Cooling Vent Replacement: 步骤 3 中的图像 3,3
    • Using a the standard Phillips head screwdriver bit, remove the slotted black plastic covering and then unscrew the one 11mm screw holding the power cord in place.
    • Unscrew the four 14 mm screws that are in the deep slots. This will release the motor from the base.
  4. Nutri Ninja BL450 Cooling Vent Replacement: 步骤 4 中的图像 1,3 Nutri Ninja BL450 Cooling Vent Replacement: 步骤 4 中的图像 2,3 Nutri Ninja BL450 Cooling Vent Replacement: 步骤 4 中的图像 3,3
    • CAUTION: the silver blade attached to the motor is very sharp. Use a towel or thick cloth to protect your hands for the next step.
    • Using a towel, hold the silver fan still. Twist the small black rubber wheel that is attached to the top of the blender base to the right. This will remove the wheel for replacement.
  5. Nutri Ninja BL450 Cooling Vent Replacement, Cooling Vent: 步骤 5 中的图像 1,2 Nutri Ninja BL450 Cooling Vent Replacement, Cooling Vent: 步骤 5 中的图像 2,2
    • Slide the cooling vent out from the silver plastic part of the blender base and replace it.
结论
Morgan Blauth
于02/24/16注册
759 声望
创作了5篇指南
团队
USF Tampa, Team 1-5, Leahy Spring 2016 USF Tampa, Team 1-5, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G5
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 1,399
