跳转到主内容
简介
Users will be able to replace the cooling pipe of their blender using this guide.
配件
没有特定配件。
  1. Nutri Ninja BL450 Cooling Pipe Replacement, Small Rubber Wheel: 步骤 1 中的图像 1,1
    • Remove the cup from the blender base.
  2. Nutri Ninja BL450 Cooling Pipe Replacement: 步骤 2 中的图像 1,2 Nutri Ninja BL450 Cooling Pipe Replacement: 步骤 2 中的图像 2,2
    • Turn the blender over and unscrew the three 14 mm screws holding the slotted base in place. These are Torx Security bits (TR9) on some units.
  3. Nutri Ninja BL450 Cooling Pipe Replacement: 步骤 3 中的图像 1,3 Nutri Ninja BL450 Cooling Pipe Replacement: 步骤 3 中的图像 2,3 Nutri Ninja BL450 Cooling Pipe Replacement: 步骤 3 中的图像 3,3
    • Using a the standard Phillips head screwdriver bit, remove the slotted black plastic covering and then unscrew the one 11mm screw holding the power cord in place.
    • Unscrew the four 14 mm screws that are in the deep slots. This will release the motor from the base.
  4. Nutri Ninja BL450 Cooling Pipe Replacement: 步骤 4 中的图像 1,3 Nutri Ninja BL450 Cooling Pipe Replacement: 步骤 4 中的图像 2,3 Nutri Ninja BL450 Cooling Pipe Replacement: 步骤 4 中的图像 3,3
    • CAUTION: the silver blade attached to the motor is very sharp. Use a towel or thick cloth to protect your hands for the next step.
    • Using a towel, hold the silver fan still. Twist the small black rubber wheel that is attached to the top of the blender base to the right. This will remove the wheel for replacement.
  5. Nutri Ninja BL450 Cooling Pipe Replacement, Cooling Pipe: 步骤 5 中的图像 1,3 Nutri Ninja BL450 Cooling Pipe Replacement, Cooling Pipe: 步骤 5 中的图像 2,3 Nutri Ninja BL450 Cooling Pipe Replacement, Cooling Pipe: 步骤 5 中的图像 3,3
    • Remove the cooling pipe from the top inside of the blender base and replace it.
结论
另外一个人完成了本指南。
Morgan Blauth
于2016年02月24日注册
747 声望分
创作了5篇指南
团队
USF Tampa, Team 1-5, Leahy Spring 2016 USF Tampa, Team 1-5, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G5
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 4
过去的30天: 25
总计 1,967
