简介
Getting into the Nuraphones is deceptively easy - simply grip and twist.
你所需要的
For fixing the "deep sleep" issue, feel for the cup that has a flexible ring (capacitive sensor) around the face-side of the cushion. It should be the right cup.
Grip the hard outer shell of the ear cup you want to disassemble.
Completely cover the soft padding area with your other hand, squeeze to grip, and twist like opening a jar.
Twist the left cup clockwise to open, and turn the right cup counter-clockwise to open.
Remove 9 Torx T7 screws from the ring of the cup
When reinstalling any plastic screw, insert the screw in the hole and rotate backwards (unscrew direction) with slight downward pressure until you feel a click - that locates the original thread and prevents stripping. Begin screwing it back in where you feel the click.
Separate the two halves of the cup, revealing the skin mounting
Fold back the skin, revealing the ear cup foam and (if fixing the Deep Sleep issue) the broken wire leading to the capacitive ring
5等其他人完成本指南。
一条评论
Oh man you just saved me prying my Nura's open with a splurger. So grateful for this! Now I can replace the crappy wire to the inner ear bud. Thanks a ton.
