跳转到主内容
加入维修社区 - 创建账户
Numpad with Keyboard Removal
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
  1. Numpad with Keyboard Removal, Before you begin: 步骤 1 中的图像 1,2 Numpad with Keyboard Removal, Before you begin: 步骤 1 中的图像 2,2
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Numpad with Keyboard Removal, Remove the touchpad spacers: 步骤 2 中的图像 1,3 Numpad with Keyboard Removal, Remove the touchpad spacers: 步骤 2 中的图像 2,3 Numpad with Keyboard Removal, Remove the touchpad spacers: 步骤 2 中的图像 3,3
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  3. Numpad with Keyboard Removal: 步骤 3 中的图像 1,1
    • Repeat the same procedure for the other touchpad spacer.
  4. Numpad with Keyboard Removal, Remove the touchpad: 步骤 4 中的图像 1,3 Numpad with Keyboard Removal, Remove the touchpad: 步骤 4 中的图像 2,3 Numpad with Keyboard Removal, Remove the touchpad: 步骤 4 中的图像 3,3
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  5. Numpad with Keyboard Removal, Remove the keyboard: 步骤 5 中的图像 1,3 Numpad with Keyboard Removal, Remove the keyboard: 步骤 5 中的图像 2,3 Numpad with Keyboard Removal, Remove the keyboard: 步骤 5 中的图像 3,3
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  6. Numpad with Keyboard Removal, Remove the numpad: 步骤 6 中的图像 1,3 Numpad with Keyboard Removal, Remove the numpad: 步骤 6 中的图像 2,3 Numpad with Keyboard Removal, Remove the numpad: 步骤 6 中的图像 3,3
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
结论
Alex Diaz-Kokaisl
于01/16/22注册
218,678 声望
创作了1,087篇指南
团队
iFixit iFixit 的会员
Staff
125 名成员
创作了24,048篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 44
