跳转到主内容
Numark TT1600 Tone Arm Replacement
你所需要的
  1. Numark TT1600 Tone Arm Replacement, Tone Arm: 步骤 1 中的图像 1,2 Numark TT1600 Tone Arm Replacement, Tone Arm: 步骤 1 中的图像 2,2
    • Flip over the turntable and remove the 9 screws on the outer edges.
  2. Numark TT1600 Tone Arm Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover by pulling it apart.
  3. Numark TT1600 Tone Arm Replacement: 步骤 3 中的图像 1,3 Numark TT1600 Tone Arm Replacement: 步骤 3 中的图像 2,3 Numark TT1600 Tone Arm Replacement: 步骤 3 中的图像 3,3
    • Remove the clip located on the backside of the audio jack housing by gently pulling it out.
    • There will be some resistance but continue to pull gently.
    • The clip is located right underneath the audio jacks.
  4. Numark TT1600 Tone Arm Replacement: 步骤 4 中的图像 1,3 Numark TT1600 Tone Arm Replacement: 步骤 4 中的图像 2,3 Numark TT1600 Tone Arm Replacement: 步骤 4 中的图像 3,3
    • Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
  5. Numark TT1600 Tone Arm Replacement: 步骤 5 中的图像 1,2 Numark TT1600 Tone Arm Replacement: 步骤 5 中的图像 2,2
    • Gently pull the wire that you just unscrewed to release it from the clip.
  6. Numark TT1600 Tone Arm Replacement: 步骤 6 中的图像 1,3 Numark TT1600 Tone Arm Replacement: 步骤 6 中的图像 2,3 Numark TT1600 Tone Arm Replacement: 步骤 6 中的图像 3,3
    • Remove the two screws connecting the circuit board to the tone arm.
  7. Numark TT1600 Tone Arm Replacement: 步骤 7 中的图像 1,2 Numark TT1600 Tone Arm Replacement: 步骤 7 中的图像 2,2
    • Remove the two remaining screws connecting the tone arm to the device.
  8. Numark TT1600 Tone Arm Replacement: 步骤 8 中的图像 1,1
    • Flip the turntable back over to the top side.
    • Remove the counter weight located at the back of the tone arm.
  9. Numark TT1600 Tone Arm Replacement: 步骤 9 中的图像 1,3 Numark TT1600 Tone Arm Replacement: 步骤 9 中的图像 2,3 Numark TT1600 Tone Arm Replacement: 步骤 9 中的图像 3,3
    • Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver.
    • Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
  10. Numark TT1600 Tone Arm Replacement: 步骤 10 中的图像 1,3 Numark TT1600 Tone Arm Replacement: 步骤 10 中的图像 2,3 Numark TT1600 Tone Arm Replacement: 步骤 10 中的图像 3,3
    • Pick up the tone arm and point the back end of it towards its base.
    • Push the back end of the tone arm into the hole.
    • Flip the turntable over and pull the tone arm all the way through the hole.
结论
3等其他人完成本指南。
Nikolai
于10/12/11注册
254 声望
创作了5篇指南
团队
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G14
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 8,211
