简介
Make sure device is unplugged.
  1. Remove slip mat from top of the platter.
    • Remove slip mat from top of the platter.
  2. Remove platter by inserting thumbs in holes and slowly pulling up.
    • Remove platter by inserting thumbs in holes and slowly pulling up.
    • There will be some initial resistance.
    • Remove damaged belt which will be located below the platter.
    • Install new belt by securing it around the inner ring, located on the back of the platter.
    • Place a thumb in each hole.
    • You should be able to feel the rubber belt.
    • Gently pull the belt with each thumb, keeping the belt taut around the inner ring.
    • Secure platter back on turntable while keeping belt taut.
    • Pull belt around motor spindle.
    • Gently let go of belt.
    • Test turntable by spinning the platter.
    • There should be slight tension causing the platter to come to a stop.
终点
另外一个人完成了本指南。
Nikolai
于2011年10月12日注册
161 信誉积分
创作了5篇指南
团队
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G14
4 名成员
创作了7篇指南
浏览统计数据:
过去的24小时: 2
过去的7天: 5
过去的30天: 43
总计 3,404
